Emergency Brake
Emergency Brake
My Emergency Brake handle will not stay up. The button is stuck inside the handle so I am trying to remove the console that is surrounding the brake handle between the seats. I removed the 4 screws on the side but it still will not come out. Is there another hidden screw somewhere?
RE: Emergency Brake
youve probably spilled some kinda coke on it didnt ya......LOL get some HOT soapy water pull off the rear console part around the Ebrake... PUT afew towels around the Ebrake handle, then slowly pour the HOT soapy water onto the button. and try to work the button... should free up with alittle worken it.. no big deal
RE: Emergency Brake
ORIGINAL: ugh3012
Based on the picture, it looks like only the four screws hold the console in. Now just slide it rearward and lift it up.
[IMG]local://upfiles/25538/91C26BB62BF24356AFA65C4AD8B10BE6.jpg[/IMG]
RE: Emergency Brake
you tried the HOT soapy water yet? youd be suprised what alittle hot soapy water poured around the button and working it can free it right up...
ive had the coke mess problem several times... with my automatic shifter... and my old Ebrake on my crx
doesnt take to much sticky residue/dirt to make it HOLD FIRM. LMFAO
ive always just poured some hot soapy water all around it... worked the stuck part around.... poured more water around it afew times till it moved very freely...
RE: Emergency Brake
ORIGINAL: addiction2bass
RE: Emergency Brake
ORIGINAL: ugh3012
Not yet. I did wack it like you would wack it after you go to the bathroom and the button came out. Get it? LOL.
sparkhard
01-15-2008 05:30 PM
