Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
I have a 2000 Civic and the dome light, trunk light will not light up, and the bell for key in ignition while the door is open will not ring nor will it ring if the lights are left on. Any ideas?
