Electrical Problem???????????????
Old 10-20-2006 | 02:11 PM
CrazyJames's Avatar
Default Electrical Problem???????????????
I replaced the timing belt on my 94 civic ex. I jumped the ecm ( I think correctly ) and set the timing. I turned the car off and saw the tail lights still on. I tried every thing I could think of and I'm starting to wonder If I jumped the ECM correctly????????????? Anyone have any ideas????????????? or details in jumping the ECM??????????
Old 10-20-2006 | 02:36 PM
AgentofDarkness's Avatar
Default RE: Electrical Problem???????????????
Whats the problem exactly? I don't think the PCM is wired into the tail light circuit
Old 10-20-2006 | 03:43 PM
CrazyJames's Avatar
The tail lights won't go out ( turn off ). About the PCM - I don't know what it is or how to check it.?????????
Old 10-20-2006 | 04:38 PM
PCM and ECM are the same thing, i tend to use PCM. I don't think your problem is with your ECM. I would chech the headlight switch (**** you turn)
Old 10-21-2006 | 10:29 PM
patcheway's Avatar
check your brake light switch may need adjusting
Old 10-21-2006 | 10:52 PM
Misha's Avatar
+1 brakes
Sporange
15
01-12-2007 01:07 PM
93HBEX
06-16-2005 01:45 PM
civicgolg
05-24-2005 04:13 PM
thirddensity
01-31-2005 03:19 PM
Norman_x
12-08-2004 02:09 PM
Quick Reply: Electrical Problem???????????????
