Electrical **** storm
The switch feeds power to the fuses. With the switch on low, probe the test points of the fuses with a test light or voltmeter, with the (-) probe grounded. You should have battery voltage to ground on both test points of each low beam fuse. Similarly on high it feeds the two high beam fuses.
