eg shocks on ek
eg shocks on ek
hey, i am gonna get the white tokico for my ek but tokico shocks are for both eg/ek... should i use washers/spacers or should i change the ek shocks bushings from the lca into the eg shocks bushings? which way works better? thanks
The bushings are pressed into the lower control arm, not the shock. The most professional way is of course to swap bushings to the 92-95 size (I think you can do that).
The easiest and still just as safe way is to use washers to fill in the gap between the EG shock bracket and the EK narrow bushing.
Both ways will work the same, it's just that one way might make you feel like it is more professionally done.
spintelect
05-17-2007 04:23 PM
Civic Mania 160
12-08-2004 11:02 PM
