Ef won't start. Starter not engaging.
#21
You want to turn the engine counterclockwise, the way it normally runs. Go through at least two full revolutions. If you can turn the engine part of a turn but then it jams, there is probably water in one of the cylinders, or the timing belt is way off and the valves are crashing.
#23
Is the battery low or dead?
Maybe you should try a push start again. Hold the clutch down with the key in ON(II) and the transmission in first gear while a buddy pushes the car or you are rolling down hill. Then pop the clutch.
#24
Thats what I had tried and it stops ridiculously fast. I'll go get my battery charged then try again :/
#30
I like that for push starting I'll keep that in mind.
bmarsh1605
12-02-2011 07:44 AM
RP Sinisterx
08-21-2010 11:38 PM
comapro
14
10-20-2008 02:05 PM
Sk8_2_rel8
10-10-2006 03:20 PM
