ECU Readiness? 97 civic hx
I need some input my ecu will not set ready on the following areas, catalyst, o2 sensor and EGR. It'll paas inspection with two not ready! Help, any input? The only code I have is pending p1491-egr lift. What is the process for getting the ecu to ready staus? Cant get inspection and cant get tag until I fix-THANKS
Clean the EGR valve and passages in the manifold (take the plate off of the top of the manifold, which requires removing the fuel rail with injectors first). Very common for it to just be clogged with carbon deposits.
Civic Si 00
12-30-2010 10:44 PM
Captain_Sl0w
08-19-2008 06:41 PM
theShamgod
08-15-2008 02:48 PM
