ECU plug not reading anything
So i have a 98 honda civic 1.6L ex. The check engine light is on. Tried a code reader and it says its not connected to anything. Checked every fuse on the car and all are fine. The car also idols jumpy and revs high at stopped position. Figured the jumpy rpms was from me taking off cruise control and a poor vacuum leak but all vacuum lines are sealed. Anybody have any other ideas?
Check engine light is on. Throttle cable seems ok and i cleaned the throttle body. Guess i need to look at the sensors next. Any idea on why the diagnostic reader when plugged in would say the device isn't plugged in to anything?
Code 67 is almost always caused by a bad cat. The only other fault that will throw code 67 is an exhaust system leak.
Make sure that you reset the ECU to make sure code 67 repeats. No need to chase non-repeating CEL codes.
If only code 67 is thrown, then the secondary O2 sensor should not be considered.
Regarding the code reader problem, this is likely a separate issue possibly due to a bad code reader, bad wire in the DLC circuit, or even a bad ECU. You first may want to recheck the DLC fuse under the hood, however.
dinanrob
09-20-2007 02:04 PM
