Ecu faulty? (a/c)
Old 06-26-2008 | 08:01 AM
u770017's Avatar
Default RE: Ecu faulty? (a/c)
so can i just jump the red/blk wire to the blue/red that why when i turn the a/c on everything comes on? and I just turn it off intermittley?
Old 06-26-2008 | 08:43 AM
Try a different relay first. There's an off chance the relay is bad and overloading things.
If it's not the relay it's the ECU. You can bypass the ECU like you describe and it will be safe to operate. It would work a little better with the ECU in the loop but that would require buying another ECU. For example it's going to stumble as the compressor comes on at idle because the ECU won't be delaying until the engine revs up.
Old 06-26-2008 | 08:59 AM
u770017's Avatar
yea i swapped relays with the fan and both work fine. I wish i just could check the continuity between the red/blk wire to the ecu.
Old 06-26-2008 | 09:16 AM
Did you measure at the ECU plug? Should be able to probe it there.
Old 06-26-2008 | 09:25 AM
u770017's Avatar
a15 or b5? what should it read?
Old 06-26-2008 | 11:19 AM
A15 is the output to the compressor relay, should read less than 1 volt or so with A/C on and battery voltage with it off but key on. This is the other end of the red/blk wire to the relay.
B5 is the input, similar readings. Since the engine idles up with the A/C on, that shows the ECU is receiving the signal on B5 and responding properly.
Old 06-30-2008 | 10:19 AM
fixerman's Avatar
I/ve been following this post and the '93 civic I am working on has the exact same problem. My freind brought it to me to replace the compressor so I put a rebuilt compressor, new accumulator and new expansion valve. Pulled a vacuum jumpped the low pressure switch and tried to charge the system. The compressor did not engage. After seeing this post I tried everything here and have come up with the exact voltages on A15 4.2v and B5 .9v with the a/c on. I have read about the a/c switches activating everything correctly but the compressor. Could this be the problem or is the .9v at B5 an acceptable readingand the ECU is the culprit?
Thanks for your help!
Old 06-30-2008 | 10:30 AM
ORIGINAL: fixerman
I/ve been following this post and the '93 civic I am working on has the exact same problem. My freind brought it to me to replace the compressor so I put a rebuilt compressor, new accumulator and new expansion valve. Pulled a vacuum jumpped the low pressure switch and tried to charge the system. The compressor did not engage. After seeing this post I tried everything here and have come up with the exact voltages on A15 4.2v and B5 .9v with the a/c on. I have read about the a/c switches activating everything correctly but the compressor. Could this be the problem or is the .9v at B5 an acceptable reading and the ECU is the culprit?
Is the thermoswitch bad?
Have you checked the clutch relay?
Is there power at the red wire leading to the compressor clutch?
Does the condenser fan run?
Old 06-30-2008 | 11:02 AM
If the engine idles up that means the ECU intends to turn the compressor on. Condenser fan should be on at that point. Then it's either the compressor relay, compressor, or ECU.
It's not necessary to jump the switch to charge the system. You will be able to get enough pressure in to close the switch without the compressor running.
Old 06-30-2008 | 05:02 PM
fixerman's Avatar
System is charged. Relays are good. Fan runs. Clutch engages when relay is jumped. Engine idle increases when a/c is turned on. Again everything is the same as the symptoms above. You mentioned the voltage issues at A15 and B5. I guess my main question is if B5 is .9v should A15 be lower than the 4.2v I am seeing?
Quick Reply: Ecu faulty? (a/c)
