Drivers door lock
Drivers door lock
The drivers door on my sons 97 excoupe will not lock. I have the door panel off and can hear the control box clicking and the passenger door is locking ok. It has been a problem on and off for a while but I need to get this locking with school starting soon. Any input? Thanks
RE: Drivers door lock
hum.... well with the drivers door open does the dome light come ON and OFF with the door open and closed?
if it doesnt it COULD BE the door contact sensor could be dirty and not making contact which COULD keep the drivers lock from locking.... just unscrew the sensor and test the wire... clean the contacts and retry it..
Have you tried reaching inside the door and manually trying to lock it from the latch assembly. Doing so would eliminate a mechanical problem. Also try disconnecting the rod from your lock cylinder to make sure that isn't keeping it from locking; it might be corroded internally. While you have the door upolstery off make sure you lubricate every thing will a good quality lubricant including the key cylinder.
could be the latch.... best thing to do it pull out the whole latch and play with it....
could just have some dirt or grit in the latch not leting it lock... or maybe a part just broke in it.... try messing with it and if it still wont work right.... just buy a new latch... i dont THINK they would be to much money....
redraif
03-07-2013 01:59 PM
The_Dealer
05-10-2009 05:54 PM
Koala
10-12-2007 09:38 PM
mikeym
05-31-2006 09:09 AM
