doorlock...
Old 01-31-2007 | 05:04 PM
02blackex's Avatar
Default doorlock...
The switch locks the driver's door lock, but not the passenger lock. Is this normal, or do I have to get it fixed?
by the way, I just got the car, i dont know if its a dumb question or not....
Old 01-31-2007 | 05:34 PM
98civex's Avatar
Default RE: doorlock...
usually it locks/unlocks both doors simultaneously. but i'm not familiar with 2002's so i'm just guessing.
Old 01-31-2007 | 09:29 PM
kinosh's Avatar
All doors should lock/unlock.The problemcould be the power door controller (inside the driver's side door), the actuator inside the passenger side door, or the wiring somewhere.I had a similar problem and found a broken wire at the door hinge, where rainwater got in and corroded the wire.
Old 02-01-2007 | 12:05 AM
02blackex's Avatar
About how much was it to fix?
Old 02-02-2007 | 08:09 PM
kinosh's Avatar
It took hours to find the problem. Once I found the problem, I went to Radio Shack andgot some wire ($3) and wire connectors ($2). And I still have a lot of leftover wire and connectors for another job.
ptextreme
07-28-2008 05:58 PM
Quick Reply: doorlock...
