door lock wont work
door lock wont work
I have a 93 civic DX and the door lock wont work, like you press the button to lock the door but the button is like loose and it doesnt lock from the inside, i need to use a key to lock it from the outside, so i cant unlock or lock it from the inside? anyone know how to fix it, also if i dont get it fixed and its still loose and what not would a power door lock work with it?
RE: door lock wont work
you can take the door panel off. there is a clip holding the window roller handle on. remove the clip with a flathead screwdriver or needlenose pliers. then there's a plastic screw near the mirror that you need to remove. then remove the interior door handle. door panel should now pop off when pulled and then lifted to get off the window slot.
were u able to fix the lock by taking the panel off ???? im having if not the same, a very similar problem I have a 1992 DX and when i try to push the lock closed to lock, it just seems to be stuck in the open position ..........now this is the interior lock "tab" thing im talking about ......the door locks fine from the outside.
redraif
03-07-2013 01:59 PM
stallion02
02-09-2011 04:40 PM
The_Dealer
05-10-2009 05:54 PM
therobesons
10-01-2008 02:51 PM
Koala
10-12-2007 09:38 PM
