dome lights dont work
my dome lights are not working and i dunno why i checked the fuses for that and they all are good my trunk light works thought also i checked to see if the dome light is getting power to see if it was the bulb and they are not getting power at all i really dont need them but would not mind fixing them and having something to mess with also it is a 2000 ex coupe
does the dome light turn on when you open the other door instead of the driver's side door? if so, the dome light switch in the doorjamb could be messed up. does the dome light work when you manually flip the switch all the way to the on position?
well accutally both dome lights are not working the forward spot light and the rear spotlight lights are not working and nope the light doesnt even come on whenever i manually flip the switch they dont work at all is what i am saying dont even turn on even if i try to manually turn them on.
How i checked to see if they were getting power was by taking the power needle tester hooking it up to the battery and putting it in the light on the wire to see if it had power or not and they are both not getting power
My dome light dont work either... lol
well i know the bulbs are not burtn out for sure cause i put new bulbs in there but i checked the fuses also i will check that fuse 43 again and yes sir that is how i checked to see if they had power put it on a ground and it did not show up it is prolly just a fuse and i checked the wrong one i will check it and let you guys know
