DOES BOTH CV AXLES SUPPOSED TO PULL HELP PLEASE
I JUST REPLACED CLUTCH IN 88 HONDA CIVIC BUT AFTER I GOT IT ALL BACK TOGETHER THE DRIVER SIDE CV JOINT WILL NOT MOVE WHEN IN GEAR CAN STOP IT WITH MY HAND IS THIS RIGHT OR SOMETHING SERIOUS WHAT IS CAUSING THIS BOTH AXLES ARE IN GOOD AND WHEN LIKE IN 3RD GEAR AND GAS ON IT THE MOTOR REVS BUT DONT WANNA GO NOWHERE CAN ANYONE HELP ME PLEASE WITH THIS THANKS
RE: DOES BOTH CV AXLES SUPPOSED TO PULL HELP PLEASE
if its an 88, its cable, but if it has a new clutch, then it should tighten it, not loosen it. unless it was screwed with during the R&R. try adjusting that, and see if it helps. its strange its only in 3rd though...
sde780
02-18-2008 05:30 PM
NEED HELP PLEASE CV
11-28-2005 10:25 PM
