Does blown head gasket cause coolant surge/bubbles?
Its one of the things I noticed in my civic, which has a totally screwed head gasket. A ton of air bubbles and smoke come from the radiator when the motor is reved.
The thing I'm wondering is, with the cap off the radiator of a car without a blown head gasket, will the coolant surge when the car is revved? Will it bubble?
I only ask cause my brothers civic does this even though it doesn't not lose coolant or indeed have any other head gasket symptoms.
What all can cause surging and bubbles?
RE: Does blown head gasket cause coolant surge/bubbles?
ORIGINAL: Jaynik
Yes, you either have a cracked head, cracked block, or a blown head gasket. Most likey a blown head gasket. The easiest way to check is with a block tester. Autozone rents them for free. You just have to buy a bottle of the solution that goes in the tool. Just follow the instructions and you'll know within 1 minute if you have a blown head gasket. It test for exhaust gases in the coolant system. It's cheap and easy to do. The tool requires a $20 deposit and the solution is about $7, and that's enough to do about 10 test. It's good to have on hand when used car shopping, it sucks to buy a car with a blown head gasket and not know it. I've been burned like that before, never again now that I know how easy it is to test.
beekay
02-11-2011 07:06 PM
cbaker1213
11-22-2008 07:23 AM
Stimpy
05-30-2007 08:55 PM
