do i need a new ecu??
Old 01-28-2008 | 04:32 PM
0slowpoke60's Avatar
Default do i need a new ecu??
Hi, i have a d15b2 in my 89 hatch. im having idle problems. i do have a y8 single cam vtec head w/intake manifold. im thinking of just trying to run the intake on my d15b2. would i need a new ecu with the intake or only if i also put the head on. and will it mount up without any mods?
Old 01-28-2008 | 04:35 PM
FlipHKD720's Avatar
Default RE: do i need a new ecu??
just the intake manifold? No, you won't need a new ECU. If you do the mini-me swap (put the y8 head on there), then yes you will need the ECU to enable the VTEC.
Old 01-28-2008 | 05:46 PM
okay, thanks alot for the help.
Old 01-28-2008 | 09:21 PM
Hailchristian's Avatar
Well....are you DPFI right now?....
the D15B2 is dual port fuel injection and if i understand you right you want to put the intake manifold from the Y8 on the b2...
in that case you would need a new ecu...you cant use the d15b2 ECU....has to be a MPFI Ob0 ecu
Old 01-29-2008 | 04:43 AM
Zackfjdm95's Avatar
ORIGINAL: FlipHKD720
a little more complicated than that , you are going to have idling problems anywyas bc of running a dif intake mani, is the idle going from1000 to 1500, then you might want to check the IACV or your throttle cable bracket.
Old 01-29-2008 | 08:32 AM
here....
http://fourthgenhatch.net/mpfi.html
Old 01-29-2008 | 12:44 PM
You have to change the ECU to one that will drive the 4 fuel injectors instead of the TBI. May as well just go for a complete mini-me job.
Civic maniac
11-30-2008 01:58 AM
Captain_Sl0w
08-19-2008 06:41 PM
theShamgod
08-15-2008 02:48 PM
xiong.s2460.mccd
07-19-2008 08:08 PM
civics101
04-14-2007 10:04 PM
Quick Reply: do i need a new ecu??
