dizzy fireing order
Old 01-01-2007 | 08:57 AM
cpl rampage's Avatar
Default dizzy fireing order
ok, i know this is a stupid question, but it has me boggled.
attached is a pic of my dizzy and sparkplug wires. the wire coming in from the left most side is cyl 1
so in essence cyl 1 wire is connected at the 9 o'clock spot on the dizzy.
but in my haynes book, it shows number 1 cyl connected to the 6 o'clock position
i looked arround online, and i couldn't really see the wires on some cars, is my current setup right or is the book right? if the book is right wouldnt my car not run, because its runs ok right now. if i did rotate the wires and it was wrong, would it damage my car?
[IMG]local://upfiles/13783/690B66B78B2C470BB6044C3E3E59BCD3.jpg[/IMG]
Old 01-01-2007 | 11:26 AM
Misha's Avatar
Default RE: dizzy fireing order
If it runs, you are OK. Relax and enjoy. If you mix two wires on 4 cyl engine, it does not run at all...
Old 01-01-2007 | 03:11 PM
Street Sniper's Avatar
Cylinder #1 - 9 o'clock
#2 - 6 o'clock
#4 - 3
#3 - 12
As far as I can see in the pic, you have it correct.
Old 01-01-2007 | 04:15 PM
baker's Avatar
it would be missing like a **** if you had just one wire wrong... so if it is running fine, then you're gravy
Old 01-01-2007 | 05:30 PM
i didnt think it was wrong, and i wasnt thinking of one wire being switched, but all of them shifed 90 degrees, cause the book shows cyl 1 at 6, but it must be wrong
AnakinKenobe
07-05-2005 11:00 AM
AnakinKenobe
05-06-2005 09:32 AM
Quick Reply: dizzy fireing order
