Dashboard Problems! BAHH
1997 Civic LX
So today i took out my dashboard because the dude that owned the car before me had a stupid aftermarket dash in that was not working.
so... i took out the aftermarket and replaced it with the stock gauges (simply, gas, engine temp, and speedo)
Now, after i have plugged all three harness' back into the back of the dash, when i put my headlights on, none of the lights on the dash come on, and if i leave the headlights on and turn the car off, the buzzer doesn't sound, letting me know that i left them on.
Also:
i don't know how to reset the gauges so i know how fast i'm going and how much gas.
the gas gauge sits at E and my speedo rests at about 30 MPHs
Also:
did the stock gauges come with the car? or did you purchase them yourself (from a wrecker perhaps?)
Did the aftermarket gauges all work properly?
My guess is that you're missing a ground or something behind the dash, although I will freely admit I'm no expert at electrical.
Not working only when the headlights are on probably means the ground wire is broken. I think there is a big ground screw right behind the cluster when you take it out. If it never works at all, there is no power to the cluster, possibly a blown fuse.
I'm not sure if the 97 even had a stock headlight reminder buzzer.
ok i fixed the problem with the dashboards lights not coming on, so now it lights up and the buzzer sounds if i leave the lights on.
but i still do not know why or how my engine temp and gas gauge are stuck and will not move without me doing it myself
pktaske
06-28-2006 02:59 PM
lifeskills
12-19-2005 02:20 PM
luckycat15
03-07-2005 08:28 PM
