d17a2 in a dx, easy swap?
I have 2002 civic dx with a d17a1 and its old. I picked up a d17a2 and was wondering if its a direct swap. Do I need the ecu for the d17a2 because its vtec? Or do I need another tranny?
I'm thinking all I need is the ecu and its a direct swap, any input?
I think if you just use the engine itself (block and head assembly), it will bolt in exactly and run like a DX (no VTEC). Later you can swap the ECU and wire up the VTEC, and swap to EX-type exhaust for higher performance.
Not saying this isn't true, but I'd love to see some evidence of this. A quick search didn't turn up anything, but this seems cool!
Also found this
blocks are identical aside from the stamp. Pistons on the A2 are slightly different than the A1 -slightly higher compression - but that's it. Hell the heads are the same casting except the that VTEC oil passage isn't drilled out and the rocker assembly is different.
