D16Y7
Old 05-30-2007 | 05:59 PM
kyleag89's Avatar
Default D16Y7
Is this a Vtech engine? Im a new civic owner D16Y7 Thanks
Old 05-30-2007 | 06:22 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: D16Y7
Hi,
First, to help you out, it's spelled VTEC, no H.
Second, no, it's not a VTEC engine, but it may have a mini-me swap on it. I would have a VTEC solenoid if it was.
Old 05-30-2007 | 06:42 PM
brokenarmboy19's Avatar
Default RE: D16Y7
Its a solid motor very little problems low power output but tunable no cam available i am going to turbo mine no mini me but thats because i don't want to spool twice
Old 05-30-2007 | 06:43 PM
kyleag89's Avatar
Default RE: D16Y7
sorry i misspelled i type to fast i kno its vtec thanks
Old 05-30-2007 | 06:49 PM
the_turtle's Avatar
Default RE: D16Y7
ORIGINAL: brokenarmboy19
no crank soley for the Y7, but any Y8 or ZC will work...check out Akmee! im going to buy that kit for my build...i will prolly use a port and polished Y7 head because i dont really care much for VTEC...
So, if you want to get rid of that Y7...ill buy it from you.
Old 05-31-2007 | 01:18 PM
little dante's Avatar
Default RE: D16Y7
thats right you can go for the mini-me swap on it, to get vtec..
get a header, 2" high flow cat kit, skun2 cams, some rota o advan rims on it... air filter plus intake...
keep the original steering wheel with airback... work with the suspension ...
with that you get get a little bit faster.. [:'(]
Old 06-01-2007 | 08:21 AM
the_turtle's Avatar
Default RE: D16Y7
do a good suspension...like a good adjustable strut/spring combo..or even better, true coil overs...and good tires...and you can rape comaros in the corners...trust me...add a little more power like a full exhaust, intake, and maybe a cam (i wouldnt even worry about vtec, in my opinion, its not worth the time and money to switch it...its not much, but still, its time i usually dont have, so thats just me) and if you have a heavy system..take it out....and that car should be pretty quick, maybe not in a straight line..but it will handle really well...
to me, going fast in a straight line is boring...going fast in the corners is wayyyy more fun!
Aaron A Archer
12-04-2011 05:30 AM
Aaron A Archer
12-03-2011 03:38 PM
sicknessjb
EK Swaps
12
08-14-2009 04:15 PM
terboracer
01-10-2005 08:50 PM
Blackhatch124
11-30-2004 10:22 AM
Quick Reply: D16Y7
