CRX CLUSTER ON DX
Old 05-17-2008 | 07:38 PM
MistaGlock's Avatar
Default RE: CRX CLUSTER ON DX
1 sec tho. i did check the schematic on the back of this is heres my findings and lol scuse my artwork haha
and the small connector
should i just rewire it based on my findings?? and sorry my phones a tad dead at the moment
Old 05-17-2008 | 07:42 PM
hatch46580's Avatar
o crap man you lost me lol...give me a few monents to figure out why my brain shut down...lol...give me a couple minutes ok, hold on.let me figure this out
Old 05-17-2008 | 07:49 PM
MistaGlock's Avatar
lol i just went out to my honda "its 10pm lol" and i just ripped the instrument cluster out. imma compare schematics on it now. but i already know they dont match
Old 05-17-2008 | 08:02 PM
hatch46580's Avatar
ok you still there??? i got this figured out but i not gonna type allthis crap if you not on here....lol so you ready it goona take a few to type. type YES if you here and goona wait...lol
Old 05-17-2008 | 08:03 PM
MistaGlock's Avatar
i will sit around. i get emails directly when someone replies to this so yes i will be on standby
Old 05-17-2008 | 08:24 PM
hatch46580's Avatar
ok your gonna have to cut some wires ok...lol.
small plug 1 threw 8..
1 ground 1F
2high beams 2E
3 trunk 4F
4 e brake 7E
5 speed sensor 2F
7 power its he yellow wire 7F
8 r turn signal 8f
1 threw 12
1 l turn signal 1E
2 belt 5F
3 temp 3E
4 fuel 6F
5 oil 8E
6 gauge lights 5E
7 dimmer 4E
8 power black and yellow 10E
9 battery 11E
10 check engine light 9E
11 tac 12E
12 blue yellow wire 6E
Do you understand? Some wires will need to be swapped. and the letters you see are with the pics i gave ya.
O and make sure your hazard button and dimmer switch is plugged in or your blinkers and dimmer will not work
Old 05-18-2008 | 12:16 AM
MistaGlock's Avatar
instead of cutting. im familiar with these plastic connectors and i think i can press a tab on it and slip the wires out to swap em. would that be easier and cleaner than cutting?
Old 05-18-2008 | 08:07 AM
hatch46580's Avatar
no those wont work cause hou have to relocate the wire. using those will only add a wire and will defeat the purpose of rewireing the cluster to work. your gonna have to cut a few wire. Now if you had the stock plugs for the new cluster you could use those. But since you dont, gotta cut them.
Old 05-18-2008 | 10:57 AM
MistaGlock's Avatar
no no no what i mean is hit the tabs on these wires so they slip out of the plastic harness
and rearrange them in the way you told me to...
Old 05-18-2008 | 11:19 AM
hatch46580's Avatar
o you mean removing the pin from the plug, yes that will work.
Quick Reply: CRX CLUSTER ON DX
