Crankshaft pulley bolt
Old 12-04-2011 | 08:38 AM
Originally Posted by cooler
so update for the record i tried disabling the ignition and bumping the key like alot suggest on youtube. did not work,
That absolutely will not work on a Civic because unlike most other cars, the engine rotates counterclockwise viewed from the front. Thus it will only make the bolt tighter.
For the rounded keyway, just put it back together and be sure to get the bolt properly tight so it doesn't come loose again. The keyway is mostly to set up the timing marks on the "balancer" pulley. You can make new marks by probing in cylinder #1 to find TDC, then measure to put the other marks on.
  #22
Old 12-05-2011 | 04:29 PM
gwl's Avatar
gwl
I once used jb weld to make another slot for the keyway. This was a temporary fix so I could line up the pulley with timing mark. Make sure the crank pulley and the bolt isn't damaged since the pulley was loose. More than likely the pulley will get loose in the future. Knowing that I used an ample supply of locktite on the pulley and bolt. You should start looking for another motor.
Karrde
12
01-24-2009 05:09 AM
Shovhed1
03-17-2008 12:58 PM
Basil
08-30-2007 09:34 AM
baker7598
01-27-2007 06:49 AM
ATF
14
05-12-2005 11:44 PM
Quick Reply: Crankshaft pulley bolt
