crankshaft bolt
Old 07-04-2006 | 04:37 PM
land9's Avatar
Default crankshaft bolt
i tried loosening the crankshaft bolt on my brothers car (89 civic d13 jdm) to change his cam belt. i got him to put car in 5th gear, with his foot on the brake while I swung out of the breaker bar but the bolt would not budge. I don't have access to a compressor (not allowed to work on our own cars in workplace - dicks) so an air-gun is out of the option, and don't have any welding equipment either.
Anyone have any suggestions?
Old 07-04-2006 | 06:15 PM
gsumano's Avatar
Default RE: crankshaft bolt
i just take the starter off and put a screwdriver on the flywheel to stop the crank from turning. Good luck
Old 07-05-2006 | 12:49 AM
99civic_boosted's Avatar
Drive to a machine shop. For $5 to $10 they will spin it loose, snug it back up. Drive home and change out the belt.
Old 07-05-2006 | 01:39 AM
riceburner700's Avatar
try putting some wd-40 on the bolt threads and let it sit over night to see if it can loosen the bolt any
Old 07-05-2006 | 12:39 PM
land9's Avatar
i can't drive it on my insurance, cops are busy on the roads lately - might try wd40
has anyone else done a timing belt on a civic? heard the crank bolts can be hard to shift (even with a gun) but i've never had a problem taking a crank bolt off by hand before
Old 07-05-2006 | 12:50 PM
jdmhatch's Avatar
ok look be careful.l find out the way the crankshaft turns. then put the breaker bar on the bolt. let the bar rest on the floor then turn the car on let the breaker bar hit the floor and the bolt will loosen but turn off car fast
Old 07-05-2006 | 01:12 PM
land9's Avatar
can't, crank spins counter-clockwise at the belt side - if i did that, it'd tighten the bolt
Old 07-05-2006 | 01:14 PM
jdmhatch's Avatar
so put the bar on the other way so it hits the floor on the other side
Old 07-05-2006 | 01:33 PM
land9's Avatar
ORIGINAL: jdmhatch
what do you mean?!
Old 07-05-2006 | 01:36 PM
jdmhatch's Avatar
put the bar on the bolt so that when the motor turns it turn the bar to hit floor the bar will stop on the floor and loosen the bolt
Quick Reply: crankshaft bolt
