cranks but wont start
i have above problem so i checked my CEL and i got 10 21 and 41
10 is air intake temp sensor
21 is VTEC solenoid
41 is heated oxygen sensor
my ? is would any of these cause it to not start and i know since im doin a mini-me i have to wire a new 02 sensor and VTEC so that will solve 2 of the problems
thanks for the advice
21 is VTEC solenoid
Especially when there's more than one code, remember the codes you have, reset the ECU, then see which if any of them re-occur. I agree with Ron, it should be starting even with those codes.
Did you just put the VTEC head on, i.e. has it ever been able to run with the mini-me setup? If it's just been put together, besides the timing, also check the valve adjustment. If someone set the valves too tight because they did it wrong, it may not start.
A car can run with CEL Light on it has nothing to do with start up. My 94 Accord LX has all lights u could think of on and till this day it runs, mind you i haven't done anything to this car and i mean anything, no tune ups or even a damn oil change just a fuel filter and spark plugs, and i've had it for almost 2 years now and yeah i know i haven't done a single oil change oh well it was to sell and i'll sell it eventually. It could be your distributor or starter that died. Very common problem in Honda's, not so cheap to fix
i just put the head on so it has not started with it before
i had the head machined by a reputable shop and told him to carefully inspect everything so im hoping nothings wrong with the valves
all cylinders are getting spark and im gonna check the timing later with a light as soon as i can get a helper
yes the fuel pump is priming...that was the first thing i checked
what is the easiest way to reset the ECU?
WishIhadVTEC
01-18-2011 04:57 AM
tj1114
01-14-2011 09:02 AM
Civicracer2910
07-11-2006 03:24 PM
black99ta
08-02-2005 05:24 AM
