Coolant problems
Old 12-26-2005 | 11:35 PM
tkozaki1's Avatar
Default Coolant problems
I just recently bought a 95 civic dx. It has 98,000 miles on it. I am loosing some coolant somewhere. The temp gauge has gone past the halfway point on two occasions. I have checked the oil and there appears to be no signs of coolant in there. Also while accelerating at times I can hear the coolant from inside the car as if it was draining. I also sometimes smell coolant from inside the car. I did find some weird substance in the radiator. I think it might have been stop leak stuff. It was like a wool texture. I looked in the past posts and couldn't find exactly what I was looking for. I'm leaning towards head gasket. I plan on doing a compression check as soon as I can. I was also thinking maybe heater core but haven't found the carpet to be wet under the console. Anyone know if the heater core leaks, if it will drain where the a/c drains? Well any help would be greatly appreciated.
Thanks,
Tom
Old 12-26-2005 | 11:45 PM
Pete's Avatar
Default RE: Coolant problems
Check your RAD for leaks. As well as all the hoses.
Old 12-26-2005 | 11:51 PM
civicexracer's Avatar
sounds like you might have been topping off the fluid level with water. Signs of that happening are losing water and overheating. because of that, the coolant/water mix is probably not 50/50. u can flush the system and refill is so its properly balanced.
Old 12-28-2005 | 07:47 PM
tkozaki1's Avatar
Nope coolant mixture is not the problem here. I'll probably get the system pressurized and look for leaks then. I'll let you guys know what I come up with.
Old 01-11-2006 | 07:51 PM
tkozaki1's Avatar
If anyone was wondering my progress on my coolant problem, it turned out just to be air in the system. I was getting good compression on each cylinder and didn't have much pressure leakage in each cylinder. I ruled out a head gasket there. Thanks for all the comments.
Tom
Old 01-11-2006 | 08:08 PM
Remmy's Avatar
Thats good. Im glad to hear you dont have a problem.
Old 01-11-2006 | 09:22 PM
mill$civic's Avatar
ORIGINAL: tkozaki1
good! ..because i had a blow head gasket and its something you dont want to deal with,expessily when you drive with it till it cant go no more im glad i got rid of that car
jeffreyminten
12-10-2012 05:46 PM
sramelyk
03-06-2012 05:54 AM
paak
14
11-19-2011 03:24 PM
EJ8_Man
08-28-2009 02:51 PM
kronos
06-15-2004 11:06 PM
