Coolant bubbling / losing coolant
I guess I'm no Bars Stop Leak professional like everybody else, but can't I just replace the gasket if need be and then refill the antifreeze and go on with my life?? Just let the copper stuff keep flowing through the system?? It's doing fine like that now, why would it matter if the gasket was fixed??
CEL is the yellow "check engine" icon light on the dashboard.
Heater doesn't work well or at all if the engine is not full of coolant.
Get the cooling system completely full, then start the engine (cold) with the radiator cap off and rev it up. If you see steady bubbling in the radiator, bad head gasket.
Still has same problem!!!!!
Could it be the block is warped or cracked? HELP!!!!!!
If you drove the car when the motor was overheating you could have warped the block.
How did you clean the top of the block where the HG mates to the head? Both surfaces need to be super clean.
Have you had the radiator tested for leaks?
RotaryPWR
08-18-2009 07:49 PM
kidintheshadows
11-27-2007 10:15 AM
mrmariner7484
12-15-2005 10:24 PM
