Consumption for D16Y8
Old 11-10-2010 | 07:22 AM
atem111's Avatar
Default Consumption for D16Y8
Team
I attemp to ask for an info about consumption for my engine D16Y8
I have a Civic 1998 , i had the engine D16y7 then i swap it to this engine D16Y8
I felt this consumption increasing , the car consumed today at least 10%/11%
Do you have any clue about this issue ?i d like to add that i have also the engine
error light therefore i tried to switch it off but without success
Recently i changed the spark but the model that i get is for D16Y7 , the
manufacturer ensure me that it will work without any problem , i m wondering
if it's the source of this high consumption
Please message me back with suggestions , really feel lost with my red civic
Old 11-10-2010 | 07:57 AM
I just double checked, and what the Manufacturer told you is true. The D16y7 and D16y8 use the same plugs and wires. Did you GAP the plugs to spec before putting them in the motor?
Old 11-10-2010 | 08:05 AM
you have a check engine light on, when you did the swap did you change the ecu and put the vtec ecu in?
pull the check engine light codes, post results
http://www.honda-tech.com/showthread.php?t=1901557
andrewatmsu
28
03-30-2006 07:58 PM
payam
17
10-15-2005 02:05 AM
Lul2x
08-09-2005 01:17 AM
StifflersMom
01-08-2005 12:41 AM
dawnw
10-26-2004 02:19 PM
Quick Reply: Consumption for D16Y8
