Condenser Fan Fuse Problem
Old 03-30-2009 | 04:56 PM
Default Condenser Fan Fuse Problem
Recently, I installed a slim a/c condenser fan. Since then, the condenser fan fuse in the under-hood fuse box randomly blows. It doesn't blow immediately, it takes a couple days.
I have checked all of the wiring and it is good.
It's a 1550 CFM, 80 watt, 10" slim fan.
Do the slim fans draw too much power for the 20A fuse that is in the fuse box?
Basically what I am trying to figure out is:
Can I use a higher rated fuse?
If so, what's the highest I can go and still be safe?
Old 03-30-2009 | 08:58 PM
I would think that the company who sold the fan can tell you what the recommended fuse rating is for it. Then go from there.
Old 03-31-2009 | 07:20 AM
The condenser fan fuse also feeds the compressor clutch, which can normally use up to 5 amps. So there's only 15 amps left for the fan. If your fan uses more than 15 amps you should run dedicated new wiring and a new relay for it to handle the higher current. Drive the coil of your new relay from the stock leads for the old fan.
Old 03-31-2009 | 07:42 AM
Alright guys, thanks for the help. I'm still waiting for a response from the seller about the amperage of the fan.
Kalikooa
07-02-2014 11:42 PM
jpcalhoun
08-03-2013 09:37 AM
jaysilver96civic
04-29-2011 06:52 AM
wattsamp
04-25-2010 08:05 AM
lecorybusier
09-08-2007 04:51 PM
