code po 420 Cat efficiency
Old 07-01-2010 | 06:03 AM
fatbagger's Avatar
Default code po 420 Cat efficiency
I have an 03 civic 1.7 code po 420 cat efficiency?? Help
Old 07-01-2010 | 07:16 AM
This code generally means that the catalytic converter is toast. Any other CEL codes? Is the engine misfiring?
Old 07-02-2010 | 05:01 AM
fatbagger's Avatar
Default Thanks Ron
Yes it had an intermitant missfire which was caused by the cam position sensor which I have replaced! Since then the Engine has run great! just keeps setting the 420 code occaisionally
Old 07-02-2010 | 06:51 AM
Unfortunately, the misfire problem that you have now fixed permanently damaged the cat.
rhobby_j
06-21-2010 08:52 PM
jpnolan
04-25-2009 04:36 PM
cshih2
04-04-2007 12:01 PM
jsoSoCal
04-24-2006 05:04 PM
zach8202
05-28-2005 07:10 PM
Quick Reply: code po 420 Cat efficiency
