is the clutch going? and noisy first gear and clunk in reverse
This is more so for my girl's civic, not mine.
1. Her clutch doesn't slip at high rpms like mine did when it was going out, but the release point is waaaay up there - you hardly have to press the clutch in to engage.
Does this mean that the clutch is on its way out too? Just at an earlier stage than mine was at when I swapped it?
2. Really noisy first gear you can hear the whine. Will replace trans fluid with clutch (its never been changed at 200K), hoping not to have to do trans b/c will replace this car in a year or two.
3. Occasional clunk clunk clunk upon reverse? Axles, CVs are all ok, checked those.
Thanks
Thanks
RE: is the clutch going? and noisy first gear and clunk in reverse
If it's a pre-1992 model with mechanical clutch instead of hydraulic, you can adjust the cable and lower the pedal. Continued operation with the cable too tight will cause the clutch to slip and fail.
Should check the trans fluid now and top up if needed.
inthezoneac
11-16-2009 12:59 PM
HaZe89
06-25-2006 01:05 PM
luk1993civic
07-30-2005 01:05 AM
