Climate/hvac controls doesnt work
Old 06-09-2008, 09:50 AM
Default RE: Climate/hvac controls doesnt work
This is a very old thread.
Old 06-09-2008, 10:16 AM
mundy5's Avatar
+1; we don't even know if the problem was solved since the original post was never updated.
Old 06-09-2008, 07:07 PM
TheJGB3's Avatar
ORIGINAL: mk378
There's a motor that controls which vents the air will come out of. It's electric, not vacuum. When you push the buttons on the control panel, does the corresponding light come on? Check that everything is plugged in, if so could be the motor or the control panel. The motor is on the heater box sort of behind the control panel. I think it can be removed without taking the dash out by reaching way up from the floorboards on the left side.
The temperature lever is purely mechanical. Check that the water valve under the hood opens fully (lever moves back toward the firewall) when you put the lever on hot. If it does the heater core may be restricted. Disconnect the heater hoses and flush it with water to check for restricted flow. This is assuming of course that the engine reaches proper operating temperature.
Are you sure it's electric and not vacuum? It is a '93 after all. I know that the Civic heater controls went electronic in '99 (hot>cold **** instead of a lever) the 98 and older have a cable driven hot>cold lever) I know my Camarousesvacuum to change vent modes, but I am not sure of a '93 Civic.
Old 06-09-2008, 07:14 PM
The 92-95 service manual shows that the mode and recirculation controls are powered by electric motors.
http://hondatech.info/downloads/Auto/Manuals/Civic/
03civex
15
10-28-2008 08:20 PM
silverbullet01
06-25-2008 10:12 AM
silverbullet01
06-22-2008 05:12 PM
bensminger2003
03-06-2006 10:28 AM
seigi
02-06-2005 03:24 PM
Quick Reply: Climate/hvac controls doesnt work
