civic makes a loud bang and then poof cant catch any gears?? anyone have any opinions
Old 06-15-2010 | 10:16 PM
wicked696's Avatar
Originally Posted by mk378
Check if the speedometer goes up when you put it in gear. If it does then the transmission is working OK but you have an axle problem, e.g. CV joint broken or axle popped out of the transmission. If the speedometer stays at zero then the problem is before the transmission (the clutch) or inside it, or the linkage to the shift lever.
thanks for the help bro, i replaced the axles cause turns out they were both snapped , but when i hooked everything up the motor doesnt even crank?? im charging the battery hoping thats what it is ..if not im screwed...
islandtuner
05-04-2009 08:54 AM
general23cmp
12-20-2008 10:43 PM
SiX
03-12-2008 12:14 PM
D17Punk
11-09-2007 11:06 AM
riceburner700
02-17-2006 01:12 AM
Quick Reply: civic makes a loud bang and then poof cant catch any gears?? anyone have any opinions
