civic electric window
Old 07-10-2007 | 06:02 AM
tacoma5050's Avatar
Default civic electric window
I am trying to diagnose why my 2001 Honda civic lx rear driver side electric window does not work. Here is what I discovered so far:
rear switch up: motor works/spins
rear switch down: motor does not work/spin
front master switch up: motor does not work/spin
front master switch down: motor does not work/spin
Voltages measured at the motor:
rear switch up: -12.0
rear switch down: - 0.1
rear switch neutral: - 1.3
front master switch up: - 1.3
front master switch down: + 1.2
front master switch neutral: - 1.3
With 12v applied to motor it works/spins
With reversed 12v applied to motor it works/spins opposite direction.
So it appears the motor is OK.
So what could the failing component be:
1. rear switch?
2. front master switch?
3. Is there a relay it could be?
4 something else?
Thanks....
Old 07-10-2007 | 10:35 AM
ebaben3's Avatar
Default RE: civic electric window
i had a cable start to fray a few years ago on my prism. take the panel off and see if the cable is still good.
Old 07-10-2007 | 11:41 AM
tacoma5050's Avatar
ORIGINAL: ebaben3
The cable looks fine. Also I forgot to mention that I had the motor out when I tested it and it did not spin for the down direction when using the switches, but it did spin both directions when I applied my own 12 volts.
gospeed
09-25-2010 04:59 PM
civic2001
01-01-2010 06:12 AM
peterhugill
12-25-2009 11:53 AM
CrazyBelk5150
05-26-2008 08:27 PM
RyanEJ2
09-17-2007 10:36 AM
Quick Reply: civic electric window
