civic died
Old 08-29-2007 | 12:45 PM
ZackG's Avatar
Default RE: civic died
oh, i dont know enough about distributors to know exactly where to check the ohms. The distributor will only slide on 1 way onto the cam, right?
Old 08-29-2007 | 01:33 PM
ZackG's Avatar
ok pep boys just called. they said the timing belt broke. $473. now i dont know how hard it is to change that on these engines. ideas?
Old 08-29-2007 | 01:34 PM
ZackG's Avatar
oh and it dying slowly really isnt representative of a timing belt, so i dont know. The mechanic said the crank gear does not move when they try to start it.
Old 08-29-2007 | 03:04 PM
i dont know about that....... cause if the timing belt snaps thiers a HIGH % that it messed up the valves! at least thats what ive always heard...
and as to it just lossing power... a timing belt snaping doesnt just loose power IT WILL MOST LIKELY MAKE A LOUD SOUND and will KILL the motor ASAP! thiers no way it would just be loosing power and then die...
Old 08-29-2007 | 03:32 PM
basbal123's Avatar
yea ^^ that why when you buy a used car always make sure it has new timing belts other wise for that same reason. you even said yourself it was electrical so stick with that, the erason why they said timing belt is beacause there trying to make a profit
Old 08-29-2007 | 03:34 PM
ya id tell them HOLD ON........... YOU WANNA SEE THE BUSTED BELT ON THE CAR STILL!!!!!
and if it looks cut I WOULD CAUSE HELL UP IN THIER!!!!!!!!
cause if it was the timing belt and it messed your head up its gonna be ALOT more money that than to fix properly!!!!!
does remind me tho... i need to change my belt.LOL ive had it for afew months now... im just to lazy to do the work cause my back up truck doesnt have AC due to it kept sliping the belt and it ATE off the clutches activation wires so no more AC
Old 08-29-2007 | 06:08 PM
ZackG's Avatar
yeah i think it is. But everytime I would try to start it, the notches on the end of the cam shaft would always be in the same spot. So it is possible the timing belt is broke. and they said the cam gear is not moving, not crank.. that was my bad.
nchapa
12-23-2007 03:38 PM
02CivicLX
12
09-18-2007 04:34 AM
jonsrich
11-20-2006 08:19 AM
civicfan87
01-03-2006 01:00 AM
AndyI
10-06-2004 09:36 AM
Quick Reply: civic died
