Civic burning excessive fuel. HELP!!
Old 11-11-2008, 08:47 AM
Originally Posted by SI fanatic
...how long does it take for the ECU to relearn the idle speed?
I would think that 20-30 minutes of driving should be sufficient. Prior to driving the car, however, reset the ECU by removing the 7.5A BACKUP fuse under the hood for 1-2 minutes and then reinserting it.
Old 11-11-2008, 09:44 AM
SI fanatic's Avatar
ok. will perform when i reach home. i will provide update once completed.
Old 11-11-2008, 10:06 AM
If the idle does not slow down with the IACV wire unplugged, that shows computer will be unable to control it. Relearning won't help. In that case you must have an air leak or bad IACV. Check that the throttle cable is slack when not pressing on the gas, and the throttle plate fully closed to the stop screw (should be fully closed inside too when that happens-- the stop screw is not used to adjust idle speed). Do you have the paper gasket properly in place under the throttle body? Silicone--- ugh.
Old 11-11-2008, 10:29 AM
SI fanatic's Avatar
mk- so you're saying silicone is a bad idea?
Old 11-12-2008, 04:42 AM
SI fanatic's Avatar
ok PROBLEM SOLVED!! The problem was the throttle plate mk. It was slightly opened causing the idle speed to be higher than it should. What I did was adjusted the stop screw and that did it. And from there I jus fined tuned the idle using the idle adjust screw. I appreciate all the help guys. I am most gr8ful.
pheng0617
02-24-2013 03:59 AM
dewey decibel
09-13-2011 12:43 PM
1992civicvx
02-05-2005 02:12 PM
dawnw
10-26-2004 02:19 PM
importmech
10-14-2004 09:25 PM
Quick Reply: Civic burning excessive fuel. HELP!!
