civic 98 ex won't start
Honda Civic EX 1998 manual. Car keeps cranking forever when I turn ingnition key and won't start. Tried jumping but still does not start.
The last time it started was when I was changing the stereo headunit and I was afraid it would drain the battery while I was testing the sound so I started it for about 2 minutes. I just changed the spark plugs and the problem still exists.. it's just a straight crank noise without any sign of choking when the ignition key is turned. No warning lights on the dash. I tried putting it in gear and giving it gas and jumping the car but that didn't work either. Any advice would be greatly appreciated, thanks!
RE: civic 98 ex won't start
a good nice easy way to test your spark if u dont already know is to take out the plug, reconnect the HT wire and hold the plug on something metal like the engine block and crank the engine you should be able to see a spark
David_S
10-24-2013 10:06 AM
mikeym
05-31-2006 09:09 AM
ShaneC
08-07-2005 05:12 PM
randocsmith
07-08-2005 05:53 PM
