Civic 7 gen Ctr noise engine braking
Old 02-28-2010 | 05:33 AM
Marxx's Avatar
Default Civic 7 gen Ctr noise engine braking
So the noise I’ve been hearing. It’s when you are doing engine braking mainly, or if you are coasting along doing 30 in 3rd. Each time you let the momentum of the car turn the engine the noise get audible. It sounds a bit like a grinding noise, possibly bearings. If you just gently touch the accelerator it almost disappears..I heard that it is possible that the bearings are making noise(Input shaft bearings)if someone had a similar problem?Car is Civic Type R Ep3 2004 95.000km..6 speed..
Old 02-28-2010 | 08:44 AM
Do you hear noise with the engine idling in neutral, that goes away when you press the clutch in? That's typically what bad input shaft bearings do.
Old 02-28-2010 | 09:45 AM
Marxx's Avatar
It is not so strong sound with the engine idling in neutral,only by engine braking..sounds like this on 10 sec..
http://www.youtube.com/watch?v=95rch-vj9cQ
Old 02-28-2010 | 09:55 AM
Should have also mentioned to check that the transmission is properly filled with Honda MTF.
If you hear any noise at all from the transmission idling in neutral, it has a bad bearing. I don't know about the 6 speed, but 5 speeds are real easy to crack open and change bearings without rebuilding all the synchros, etc.
Old 02-28-2010 | 10:00 AM
Marxx's Avatar
New Honda MTF3 oil is in the transmision,when the car was on the lift and when I put it into gear(1,2,3)sound is gone,only when the car is on the road the sound is there..but only on engine braking,vhen i akcelarate nothing to hear..
rdrage73
03-27-2009 01:43 PM
Mechanixs02
07-24-2008 10:52 PM
Mechanixs02
07-24-2008 06:06 AM
burgernuds
10-12-2007 08:16 PM
point break 92
08-29-2007 11:03 AM
Quick Reply: Civic 7 gen Ctr noise engine braking
