check enigne codes
Old 02-03-2007 | 03:38 PM
DreamTeam87's Avatar
Default check enigne codes
Is you check engine light on.... if so read on...
Old 02-03-2007 | 04:06 PM
Default RE: check enigne codes
Ifoundthis and this is for anyone else who may need it..... Very helpful!!
Old 02-03-2007 | 04:08 PM
[align=center]Diagnostic Trouble Code Identification
OBD1[/align][align=center]LED, MIL & Check Engine Lamp Flash
Engine Control Module
HO2S Or O2S
HO2S Or O2S{2}
VSS{1}
MAP Sensor
CKP Sensor{2}
Vacuum Switch{1}
MAP Sensor
ECT Sensor
TP Sensor{2}
M/T Clutch Switch Signal{1}
A/T Shift Position Signal{1}
TDC{2}
Ignition Coil Signal{1}
No. 1 Cylinder Position Sensor
IAT Sensor
12
EGR System
13
BARO Sensor
14
IAC Valve{2}
EACV{1}
15
Ignition Output Signal
16
Fuel Injector System
17
VSS
19
Lock-Up Solenoid Valve
20
Electric Load Detector
21
VTEC Solenoid Valve
22
VTEC Pressure Switch
23
KS
30
A/T FI Signal A
31
A/T FI Signal B
41
HO2S Heater
43
Fuel Supply System
48
HO2S{3}
{1}PGM-CARB.
{2}PGM-FI four cylinder engines.
{3}D5Z1 engine except California.
[/align]
Old 02-03-2007 | 04:22 PM
Retrieving Codes
With ignition off, insert jumper wire in service check connector terminals, located behind right side of dash on Accord, Civic and Civic Del Sol and near center console on Prelude.
Turn ignition switch to ON position. Diagnostic Trouble Codes (DTCs) will be indicated by a series of long and short flashes on MIL.
The number of long flashes indicates the number in the 10s column. The number of short flashes indicates the number in the 1s column. For example, 4 long flashes followed by 3 short flashes would indicate DTC 43.
Old 02-03-2007 | 04:40 PM
Tater's Avatar
w00t thank you for that
Old 02-03-2007 | 04:50 PM
If you have OBDII just check this page out its where i got all my information proided above http://www.troublecodes.net/honda/....
01 honda
04-05-2007 08:26 AM
Methu969
01-22-2007 01:16 PM
Methu969
01-22-2007 01:13 PM
mobbology
11-29-2006 05:37 PM
emericanidol
01-19-2006 12:47 PM
Quick Reply: check enigne codes
