Check engine light will not go away on civic 98!
Old 02-22-2007 | 10:53 AM
yairsaenz83's Avatar
Default Check engine light will not go away on civic 98!
I got a po137 code from a diagnosis. It is the secondary o2 sensor having too low of voltage for normal operations. (sorry for the long story, I just want to put as much info as possible.)
I replaced with a universal Denso o2 sensor. I made 100% sure that the wires were spliced correctly according to the instructions the sensor came with. After installing the new sensor, I disconnected both battery terminals for about 10 minutes. A day later the cel popped up again! I'm guessing there is a loose wire somewhere?
Old 02-22-2007 | 12:35 PM
fglaustin's Avatar
Default RE: Check engine light will not go away on civic 98!
that was short;
a day later - were you driving it in that time ??
need to get the code; may be something different that showed up
Old 02-22-2007 | 01:32 PM
FlipHKD720's Avatar
Splicing o2 sensor wires is usually really iffy.....why did you need to splice/cut them? Usually with the new sensor its just plug and play (at the harness in the engine bay)
Old 02-22-2007 | 07:41 PM
fglaustin's Avatar
those universal ones are cheaper but just have one (or two) bare wires on the end
Rool_908
01-03-2012 07:03 AM
mhlden
10-02-2011 07:14 AM
Lambo Civic
09-17-2011 04:05 AM
towelie
08-30-2010 05:08 PM
MasterJT
05-15-2010 05:45 PM
Quick Reply: Check engine light will not go away on civic 98!
