Check Engine Light-Emissions
I recently changed the ignition coil on my 99 Civic EX 4-door. (Found solution here) Shortly thereafter, the yellow CEL came on regarding emissions. I picked up an aftermarket coil from Auto Zone. Does changing out the coil affect the emissions in any way causing the light to go on? Tried the gas cap procedure and light will not go out. What are my options short of taking it to the deealer?
RE: Check Engine Light-Emissions
Got a 0420 code Bank 1. changed out Primary o2 sensor. Reset light. Light came back on after a day. Ever since I put in that new coil, the idle has been off a little. Every now and then the idle drops to almost zero and feels like it wants to cut out. The exhaust also smells like the car is running rich. What is going on??
mhlden
10-02-2011 07:14 AM
towelie
08-30-2010 05:08 PM
dblclutchin
10-12-2006 12:40 AM
