check engine light comes on
Old 08-02-2007 | 01:13 PM
m_10's Avatar
Default RE: check engine light comes on
i can't check for any codes because the check light won't shut of for those first 10 seconds. I've even taken it to a mechanic and it won't even read it there. they can't even tell me what's wrong with it either
m_10's Avatar
i've checked all the fuses also. and there's nothing wrong with them.
Old 08-02-2007 | 05:47 PM
neojedi78's Avatar
What, no codes? No way.. if your ECU wasn't functioning your car wouldn't keep running. As for the quick start... well old cars have a lot of old parts. When you turn the key to acc, that is when the injectors are primed, hear the humming.. thats good. If your car doesn't start quick, you are still ok, the vacuum and priming are a mandatory function without that nothing would start. To make your car start quicker, invest in your power distribution... starter,plugs,wires, coil setup. New connections to all those listed will provide a quicker start. If that doesnt help, look at your fuel delivery, filter, pressure, flow. I wok at NAPA, so if you need to clena your injectors, we dont charge much, as long as the one you go to has the setup we do.Actually my car starts quicker if I start as the priming cycle is going, sometimes it stalls after a full prime. In the old days on the first cars, they had to prep the valves before a start, imagine a winter morning in the midwest, and still having to manualy crank your engine to start,be happy your car starts. Innovations can only go so far..
Old 08-02-2007 | 05:49 PM
neojedi78's Avatar
I forgot to say that when the check light comes on it mean the ecu is working and running a check on the systems, if the light goes out that means you good yo! Maybe your ECU is about to go bad if it really starts that rough.
Old 08-02-2007 | 05:52 PM
ej6buddy's Avatar
it also illuminates to make the driver aware that the cel bulb still works.
Old 08-02-2007 | 06:24 PM
m_10's Avatar
How could i check the fuel delivery amd pressure on my own?
Old 08-04-2007 | 04:13 PM
m_10's Avatar
Default help!!!
Can I get more advice on this cause the injectors don't get primed till the key has been on ACC for 10 seconds. I want to here that humming sound right away when I put my key on ACC.
denisholden
11-25-2007 07:56 PM
natas638
02-01-2007 12:13 PM
rollis3
07-09-2006 07:51 PM
andeeuk
01-19-2006 01:34 AM
hockeyc574
06-22-2005 12:22 PM
Quick Reply: check engine light comes on
