Check engine light
Old 01-22-2008, 05:18 PM
Default RE: Check engine light
Don't buy from Autozone, unless you want to replace the same item this time next year. Stores like that are good for panic mode repairs. Napa (dealers use Napa) or the dealership will give you the best parts, not the cheapest, but the best quality. Not an opinion, experience on several different cars and trucks and a variety of parts. FYI
Old 01-22-2008, 11:02 PM
Civic Si 00's Avatar
ORIGINAL: flattops
You are so wrong. Auto Zone sells Denso = the same as Honda OEM . But Denso is kind of expensive...But I don't mind.. I have purchased them on the past. OEM style plugs.
Denso also sells a universal (runs about 70.00)but you have to use your old plug..But if you don't connected it right or even if moisture gets in the connectors it will probably start trowing the O2 sensor code..That's the reason I stick with the OE style of plugs so i wont run that risk. But the OEM style can run up to 250.00. Yeah I know it;s expensive
miguel11691
11-15-2015 08:11 PM
Rool_908
01-03-2012 07:03 AM
mhlden
10-02-2011 07:14 AM
towelie
08-30-2010 05:08 PM
Benny Sim
07-19-2005 07:43 PM
Quick Reply: Check engine light
