Check engine light 2006 honda civic no code
Old 12-23-2010 | 12:59 PM
gracie's Avatar
Default Check engine light 2006 honda civic no code
I have a 2006 honda civic that has had several problems. Blew a head gasket in august and now when im driving slow (in traffic for example) it grinds in first gear. today the check engine light came on i went to go get the code checked and they said there is nothing wrong with it and it's not giving them any "error code". has this happened to anyone?
Old 12-23-2010 | 06:20 PM
If the light is on, there is a code. Codes related to an automatic transmission might not appear on all scanners though. You may need to go to a dealer.
Old 12-24-2010 | 01:39 AM
gracie's Avatar
thank you!! good to know
Old 12-29-2010 | 04:06 AM
gracie's Avatar
I put some oil in the car drive it for a day and the ligth stayed on...we had a huge snow storm so didn't touch the car for 5 days got in it today and the light went off... is this normal or should i go get it checked?
Old 12-29-2010 | 04:19 AM
The code should still be stored in the computer, even if the light is off.
It was on for a reason. You should still get it checked out.
Old 12-29-2010 | 04:42 AM
Problems can sort of resolve themselves (or drop below what the ECU can detect) and the light will go out.
Check the transmission fluid too. If it is low, make sure to use only the recommended type. And find out where it is leaking.
Running low or out of oil in the engine isn't a condition that is intended to turn the CEL on. Your engine will just destroy itself.
TiaMarie
09-14-2011 09:25 PM
zetojericho
08-01-2011 06:09 AM
chartpatten
12-24-2010 08:25 AM
Ed Fisher
06-22-2010 01:52 AM
shark
08-26-2009 07:54 AM
Quick Reply: Check engine light 2006 honda civic no code
