Check engine issue, gas cap?
Hi,
I've searched the forum for check engine light issues but I haven't found what I was looking for.
It a Civic 2004, DX coupe.
I've had my car for about 1½ month. In fact, I should say half a month. The car has spent the first month of ownership at the dealer for transmission issues. Happily, these issues are gone and my transmission has been rebuilt under warranty.
During the first few days of ownership, when I got to refuel the car, my check engine light came on about 10 minutes after I did so. I looked in the owners manual and read that it could be my gas cap being not tightened enough. So I tightened it properly (even though I thought it was tightened enough), and then reset the code by disconnecting the battery for a few seconds. It then turned off. So, the car then went to the dealership as I mentioned for 1 month. When I received it one week ago, the light was still off, so I concluded that the supposedly problem was gone.
Then I refuelled yesterday, being really careful to tighten the gas cap more than enough.
Today, while driving on the highway, the light came on again... I don't want to reset the code that time since I don't want to bury the problem. I'd rather solve it!
It might help you if told you that my car runs great with no apparent engine problem. It starts right away when I turn on the key. The idle is fine. The engine is responsive and as far as I can tell, the gas consumption has not gone bad but still, I want to get rid of the problem.
Could it be a simple bad gas cap?
Thank you in advance
Yeah, well, that's definitely what I would do if I lived in the USA.. but in Canada, or at least here in Montreal, we don't have Autozone. I stopped at Napa today, and they don't offer that service.
we have a napa around here too... a bunch of old people who dont like imports.. anyhow, pull the carpet away from the ecu (passenger side floor), and there should be a blinking light.. count how many blinks its giving you when you start the car. then post it here.
or you can do it the ghetto way.. buy an obd scanner, plug it in, see what code it is, and return it XD
another lesson learned young one ...lol.
but that is a good idea on buying the scanner using it then return it,
get your cel codes pulled and it will tell you why, then you can fix it, instead of guessing and wasting money.
So, it looks like I'm experiencing another issue.
I've not own that car for a while, so you'll be better placed to tell me if my issue really is one.
Since I fuelled the car 2 days ago, 130km later, my fuel gauge has not moved from the top. The needle is still above the last mark.
Am I crazy or is my car really fuel efficient? (This is the first time I fill it full)
mudhenFUF
01-16-2023 09:43 PM
fclaridge
01-27-2015 04:07 PM
