Check Engine Code PO132
In the end, purchase the sensor that you can afford. If you can afford it, I would recommend the Honda sensor, though I understand that it is expensive.
I echo mk's point. It's still possible that the sensor is fine. Therefore, prior to purchasing a new expensive sensor, raise the front end on jack stands and inspect the O2 sensor and its wires for damage. Also note whether the sensor and wires are covered in oil, which can impede sensor function.
ptw711
03-03-2013 01:36 PM
94civicexvtec
12-15-2006 11:00 AM
ch1ngg
04-18-2006 08:59 AM
johhny b
03-29-2006 12:05 PM
