Changing out ECUs
Changing out ECUs
Where can a person find a used ECU at a reasonable price? I've got a 2000 Civic HX that is telling me after a lot of diagnostic testing (and replacing EGR valves, etc.) that the ECU (P2N) is bad and I'd like to find a replacement. I'm not trying to get higher performance. My main goals are high mpg and no CELs. Then, once I've got one, will it be just plugging it in and driving, or will I have to take it to a dealer or performance shop to get it programmed or whatever? Thanks.
Funny you should ask
RonJ, you're the guy that helped me a lot by linking to the detailed diagnostic flow-chart that I used and that seems to indicate the ECU is messing up. It was P1491 and the passages were completely gunked up in the intake manifold. I didn't get into the head to clean it though. According to the flow chart, it seems like it must be the ECU based on a couple of the tests, I don't remember which, but the EGR valve was sending the right messages and the wires were good in between. So, where can I find an ECU? Don't good ones get swapped out by the high performance enthusiasts? Thanks.
My ECU is a 37820 P2N A33. I understand 37820 just means ECU. P2N is the model or something? "A" means US and I guess 33 is something like the version or update. I can find P2Ns online, but what about the last two numbers? Do they have to match or will any of them work without throwing CELs?
Captain_Sl0w
10-21-2008 04:44 AM
JDM MIKE
02-19-2008 08:54 PM
1997, 2000, 37820p2na33, bad, changing, chart, civic, diagnostic, ecu, ecus, flow, forum, helm, honda, hx, information, p2n, transferred
