car problems
Old 05-17-2008 | 12:40 PM
x1guy's Avatar
Default car problems
its not a civic but my daily is a civic and i just needed some help with this car i picked up.
so the guy told me that it needs a new catylitic converter and that it needs an air filter,
master cylinder ( i think .. he said it was for the brakes) also he said the fuel filter needs to be replaced and thedistributor too. so as i drove the car back to my house i notice that it brakes like crap so i figure its the master cylinder than i try to speed up a bit and i had totally no acceleration at all i was going about 50 tops and hardly even that. i know its probably not enough information but can anybody help me out? the car is an ae86
86 corolla
Old 05-17-2008 | 07:34 PM
enigma34's Avatar
Default RE: car problems
ORIGINAL: x1guy
86 corolla
seafoam.
Old 05-18-2008 | 05:37 AM
Brakes:
First check the brake fluid level in the master cylinder reservoir. Fill if low. Check for leaks around master cylinder, calipers, and wheel cylinders. Replace any leaking components. If no leaks anywhere but brakes are still spongy, then air may be in the hydraulic system. Bleed the system starting with the wheel furthest from the master cylinder. If bleeding doesn't fix, then you may need to replace master cylinder.
Low power:
Start with a basic tune up - replace plugs, plug wires, distributor cap, rotor, and air filter. If problem persists, then you might have a clogged catalytic converter.
Old 05-18-2008 | 09:49 AM
x1guy's Avatar
thanks for the replies.
He said theres a small leak and also said something about the vac assist brake booster
i guess i should replace that too.
Innovators
11-09-2007 08:50 PM
BabyGangsta
06-09-2006 12:42 PM
angelicnoir
05-08-2006 05:32 AM
SkeetFresh
02-22-2006 09:08 PM
civic96RB
09-22-2005 03:10 PM
Quick Reply: car problems
