Can't Start Car
Old 09-14-2006 | 02:03 PM
riverkee's Avatar
Default Can't Start Car
I allowed my daughter to start the engine on my 96 civic. She held the iginition a little too long - 1-2 seconds longer than she should have. The car started up. However, when I tried to start it back up, I heard a loud clicking noise from the glove compartment box. I opened the hood and tried to start it again to hear where the clicking was coming from. Obviously, it's near the passenger side but it was not as loud as the sounds from the glove compartment box.
During a later attempt to start it again, I noticed the clicking noise was not as loud like a power drain or something??? Any ideas on what it could be?
Old 09-14-2006 | 02:08 PM
AgentofDarkness's Avatar
Default RE: Can't Start Car
Charge up the battery, you might have run the battery down. The click is the starter solenoid engaging. Is the sound from the glove comparment or the engine? The starter is on the passanger side of the car by the trans.
Old 09-14-2006 | 02:46 PM
riverkee's Avatar
The sound was/is loudest from the glove compartment. The car's interior light and panel lights come on and with the clicking noise, a buzzing sound can be heard from the dash.
Old 09-14-2006 | 06:49 PM
fglaustin's Avatar
need the battery checked at an auto parts store (or where ever).
if that is not easy, then need to jump it.
cannot tell if it is the battery or the solenoid.
if the jump doesn't work or the battery is Ok, then need to take the starter off to an
auto parts store and have it checked.
before all of this, though, need to clean the cable ends and the battery post and make sure they are tight when reinstalling.
Old 09-14-2006 | 11:20 PM
cyberx32's Avatar
Holding the key longer on the on position makes the starter do a nasty grinding noise, but two seconds wont do too much to it. Like they said check the battery or the starter.
Old 09-15-2006 | 12:29 AM
deserthonda's Avatar
do the caveman test...........
have someone try to start the car when it clicks, get a big screwdriver or a metal pipe and bang on the starter, if it starts,, replace the starter
Old 09-18-2006 | 10:27 AM
riverkee's Avatar
Turns out the grinding of the ignition was just a coincidence. I was able to jump it. When I drove it around for a bit and stopped, it wouldn't start back up. It was the battery and I purchased a new one for around $50. Odd thing is I don't remember that click click sound when the battery died the last time.
Old 09-18-2006 | 12:29 PM
fglaustin's Avatar
either the battery had enough power to barely turn it over, or it did not have enough to even click the solenoid
dkd
11-30-2020 07:38 PM
David_S
10-24-2013 10:06 AM
...NEED4SPEED...
04-20-2010 03:55 PM
Ronin Inc
EG Swaps
07-10-2008 06:29 PM
forrealb50
15
11-12-2006 01:52 PM
Quick Reply: Can't Start Car
