Can't open back door
RE: Can't open back door
I took the inside handle off so I could get at the rods. There is no resistance when I move the door open rod (as if it is disconnected) and the lock rod will not move. I think when someone tried to break into it they bent, broke or disconnected something.
Rick
Rick
Have you tried muscling the lock rod? If you push it to the unlocked position, then you might be able to open the door using the outside door handle.
Alternatively, a locksmith might be able to open the door using a Slim Jim tool.
zealot910@gmail.com
02-19-2005 02:11 PM
