Can you repair axles??
Old 10-22-2007 | 09:26 PM
skibum853's Avatar
Default Can you repair axles??
OK, the drivers side axle i got with my swap has all the threads on the spindle just destroyed. well i have some good axles for civics lying around but they wont fit my engine (halfshaft is different). so i was wondering if its possible to take the spindle from the good one and put it on the bad one??? i really hope so cuze it turns out that because of the halfshaft being different on the b16b from most other usdm civics that it almost looks like im going to have to order one from japan or something. sounds really expensive to me
Old 10-22-2007 | 10:12 PM
Marty's Avatar
Default RE: Can you repair axles??
Go to advanced auto parts or where ever and get a axle for a 99/00 Integra type r
Old 10-23-2007 | 07:18 AM
The wheel spindle and outer joint cup are one piece. If the other axle has a bad outer joint there's nothing you could do, since both spindle/cup units are bad.
You can switch the inner joints pretty simply though.
Old 10-23-2007 | 09:18 PM
skibum853's Avatar
ok, what i have is 3 good axles from various civics, then i have the one with the messed up threads that came with the motor. can the cup and spindle from one of the good ones be swapped with the bad cupspindle?
Old 10-24-2007 | 07:10 AM
The outer joint isn't intended to be taken apart in the field. Obviously it must come apart somehow...
But if you have one with the right length axle you might be able to switch the inner joint to have the transmission shaft be the right one for your transmission.
Old 10-24-2007 | 07:28 AM
mxs's Avatar
mxs
ORIGINAL: mk378
We tried to do this once and it's not really serviceable. It is a press fitting, you need a slide hammer to take it apart, etc.
All US 94-01 Integra and 99-00 Si axles are interchangeable. Some of the later JDM Integra used larger 36mm axles, but if yours are 32mm then you can use any of the above.
Old 10-24-2007 | 06:16 PM
skibum853's Avatar
sweet thanks for the help. ordered a new drivers side one for a 99 civic si today. only cost me 130. was kinda suprised. thanks for the help again guys
Old 10-24-2007 | 06:51 PM
mxs's Avatar
mxs
where did you buy it? if it's from a parts store you can probably return the bad one and get a core deposit back
Old 10-27-2007 | 12:37 AM
skibum853's Avatar
i bought it from honda direct and i got the core out of the old one
carid
10-16-2014 02:15 AM
Dr.Who
02-26-2014 10:17 AM
addiction2bass
09-10-2007 08:35 AM
1997civic
08-03-2007 12:21 AM
